Re: 60 Degree DIY Mid Hi
Looks great Mark! Can't wait to hear your report on testing and using them.
I also wonder how good these could sound using the new QSC 4 channel DSP amps. Channels 1+2 for the 12"s and 3 and 4 biamp the 4594. That could be a potent combination I think for a lounge-level provider.
so, which one is the preferred 12" for the 90 degree version: B&C or RCF (I need to buy both...:blushThe new boxes are using the B&C ...
so, which one is the preferred 12" for the 90 degree version: B&C or RCF (I need to buy both...:blush![]()
Peter...WOW!!!!
OK, don't have the 4594HE's yet, but decided to see if the weathered 4594 loaner I've been using to make sure things fit, would by any chance still run.
So, my processing for this 'what the heck trial' consisted of a slider and amp for the passive fed coax, a slider and amp for the 12" mids, and of course a slider and amp for a sub. (X'ed-over @ 100 and 700 via X-32.)
Move sliders to taste hahaha....no eq....
Amazing just at that....YIKES what clarity and power!
In the living room, the box ran past the first Orbit Shifter as I got more confident with increasing level....
....powered up second orbit shifter. Risky indoors....kitchen counter emptied...bottle of wine, pots and pans, all hit the floor without me hearing them :blush:
And lord did the DIY just keep singing !
And it just gets better from here? with the HE and tuning ?!?
Clarity is already stunning...
I'm thinking I'm gonna need some more Labhorns outdoors :lol:
WOW Peter....
3TX on right of DIY..
Hi Mark,
I must confess I have quietly been hoping you would have that reaction when you fired them up J
Peter, I was able to get the 60 degs out for testing and tuning Saturday. I too was a little anxious on what the results would be.
Per your suggestion the box being tested was 4 meters up with the mic 2 meters out using pink noise and Smaart7 and a driverack 480.
I used your basic x-over points plus 4 filters on the mids, 2 on the HF and 1 on the VHF.
Attached is the TF and phase trace after tuning. I wasn't able to spend as much time as I would like fine tuning but was pretty happy with the results.
There is a dip at about 500hz that is either a box anomaly or ground reflection since it was present in both boxes and unaffected by any processing. I noticed the corresponding dip in the phase trace but I'm not that good at Smaart to interpret what it means. I'd love to hear feedback on the plots, I know they can be better.
My initial observations are this box gets loud and sounds good doing so. I was please with how well the highs held up even a long way from the speaker. I'll post a quick phone video I did in another post.
I was hearing details in mp4s I hadn't heard before. The 60 deg horn falls off very quickly off axis so for one a side I will use the HF950's once I get them. I later added 2 SRX718 subs and they couldn't keep up with one box. Two double 18's per your previous post would be about right.
With your excellent design, a lounge level guy like me was able to get what I feel are really good results and a great sounding box. The next big test will be at a live gig.
Don, really glad to see things have come together for you and you are already testing ! I have 3 days of Smaart training early next month and hope to learn enough to join the testing/tuning party.
Peter, thx for ongoing tuning/alignment comments..!
I got the HE's into both boxes and was able to do a fair amount of listening over the weekend. But mostly indoors due to alot of rain.....
I have been listening to uncompressed music, and also hearing things I haven't heard before.
The things I'm hearing seem to be beyond simple differences in freq response between speakers. Things like warbling or tonal modulation, that I have not heard in songs before. Really cool.
The other thing I'm liking is the low mid guts the boxes have. I'm feeling vibrations, and hearing household resonances, that are above subwoofer range, MUCH stronger than I'm used to experiencing.
During the one brief spurt I did get them outdoors, there was excessive wind and boat noise to overcome, for any real evaluation.
A 20 amp breaker that was dedicated solely to 2 bridged plx3402's powering a pair of orbit shifters, popped trying to keep up with DIYs.
I think a pair of DIYs will make a pretty good match for 4 labhorns...looking forward to trying that.....
Brandon, I used 18mm BB for what I call the inner shell (the MF baffle boards, MF horn fold, and 4594 baffle), and 15mm BB for the exterior box and braces.
I kept the inside shell width per Don's 90 degree drawing for the important reason Peter said, and then kept the MF horn path dimensions the same as the 90 deg drawings.
So as you mentioned, just a mm or two here or there...more a matter of PIA adjustments than anything...
So this box measures very close to the original HF950 plans. It came in at 77lbs without grill or pole mount.....this is about the only thing I don't like so far.
FWIW, I would not use 18mm BB again for any part. I would use 15mm for the entire box, or probably even try using 15mm for the inner shell, and 12mm for the box. I get the latter would cut almost 10lbs off.
Hi Mark,
Sorry about the weight – Using 16mm ply my new boxes came in at 34 Kgs or 75lbs with fly track and a pole mount.
Despite that there is nothing on the market that I’m aware, irrespective of price, that can make that much SPL, sound that good and weigh so little. The idea was to push the boundaries of a pole mountable speaker to the limit, to provide the SPL you would get out of something like an EAW KF850 but on a stick. Accordingly the DIY is about as big and as heavy as I think youcan reasonably get away with for a pole mount.
FWIW I think I saved a little weight cutting the back corner of the box at 40 degrees and replacing the angled section with some 12mm ply.
This is what I said earlier somewhere …
“The things I don’t like about thedesign;
· At 34 Kgs it’s a little difficult to lift onto the“stick”
· Having the horn located in the middle of the box solves a lot of acoustic problems but you need to lift the box a little higher.”
What you will find with this box because it behaves so well, any small changes will make a very noticeable difference.
