People seem to be quite defensive of the X32, it seems this is the 2nd time someone has called user error on me when I mentioned issues with it and the previous incidents where I had to send 3 of them back for repair over the course of a year were certainly not operator error. Anyway, if what you say is correct regarding the info being stored in scenes and not the show file, then everything should have loaded up properly. Yes there were channel and parameter safes, but that doesn't explain why certain parameters that were safe'd loaded up properly and others didn't.
It's possible I have an incorrect understanding of what the show file is supposed to save. My understanding is that it should save the console in it's current state (or last saved scene state) and be able to load a different console an identical configuration with all the scenes and all the parameter and channel safes still intact. If it's only supposed to save all the scenes and not save config stuff like custom encoders, safes etc...then we can call it operator error (or operator misunderstanding).
If it has happened three times on different consoles, it is probably a systematic user error. It is obviously very difficult to analyze what you are doing when the problem occurs, I can only suggest that you go through your routines, maybe look for parameter safes that you weren't aware of. Have you looked at the scenes and confirmed that the settings are not saved? Have you tried to replicate the problem?
