Re: Listening Get Together
And the proposed "response to 20 hz" is actually 18dB down from the main response.
Not many people call 18dB down "response to".
Maybe I am reading the graph wrong.
As best I can tell by the attached graph is that the sensitivity (based on 8 ohms) is around 98dB. Not exactly "ground breaking".The HP is recommended to avoid damage to the transducers, not a requirement if you don't mind damaged transducers.
The 36 volt measurement showing about an 8 dB dip in response at 70 Hz (generally indicative of a serious phase cancellation which usually can not be fixed with EQ) was on the BigE website in the same "War Ad Slick" that recommended the HP.
