Re: X16 Preview
You've made it quite clear a number of times that you don't do "bargain basement" gigs... so I guess I'm confused as to why you continually hang out in threads for equipment that you will apparently never use because it doesn't meet your requirements and you can afford more expensive gear that can?
What's the point? If I could afford some of those higher end consoles would I much rather have them? Maybe. But the X32 and X16 serve particular market needs and I'm thankful companies like Behringer are filling them. I'm just not sure what you get from threadcrapping on them?
Your customer base and clients are probably very different from most of ours. Our clients don't have a hissy fit because we run snakes or that the featured entertainers expect an FOH console to be in the house. We don't do bar gigs for the most part (boss will briefcase a bar gig as a favor to old musician friends), we don't do weddings, we don't do a lot of stuff where the mere suggestion of technical gear makes a client apoplectic.
