Re: X32 Discussion
I did try your first suggestion, but if I chose card return as channel source, then I cant set the MICPRE gain, so this is not good.
your second suggestion only allows just a few inserts...
Any other suggestion?
thanks,
Tamas
There are a couple of ways, if you send all your input channels to the card, and insert effects on some channels in the computer before returning to the outputs of the individual channels, then you'll have insert if you select card return as source on the channels you want inserts on. (Haven't tried, but imagine it should work)
The other way is to assign aux outs to card, taking aux returns from card, and using aux as inserts on the channels you want the inserts.
thanks,
Tamas
