Hi Paul,
Thanks for bringing this to our attention. I think the problem here is that you have the channel source set to off, I have just replicated the issue here in our UK care centre, I too can see the ghosting "X", this is normal when you toggle that quickly between layers where a screen is off on one layer and then "on", on another. Try the following:
Press SELECT above the affected channel
Press HOME
Navigate accross to CONFIG
Using the 3rd encoder scroll and select the input source for that channel.
Click encoder to confirm.
If however you feel you have a fault with the screen then please don't hesitate to PM me and we'll get the issue resolved for you asap
~:smile:
Kind Regards
Jim Knowles
CARE EMEA / Tech Support
MUSIC Group / BEHRINGER
