Re: How to do an analog insert?
The downside I see is that you are using up so much of the console's resources. Eight auxes! I wouldn't have enough left to do all the other things I need on your average corporate show. But you are correct, and indeed the returns could all be buried on a lower layer and be forgotten about.
Mick Berg.
If you were only doing 8 channels of automixer whats the downside of assigning 8 individual post fader auxes to the ins on the dugan and return the returns to another set of channels and unassign the outs of the channels that you are feeding the dugan from and use the inserts as your feeds to L,R or a buss with an onboard eq inserted into. Scenario below:
Wireless Lav 1 post fader Aux 1 unassign outputs so the out is ONLY going to the input of the Dugan
Wireless Lav 2 post fader Aux 2.....
Return output 1 of the dugan to channel 9 and assign it as it was an input from the mic but push the fader to unity as your not going to see signal to this input unless the fader to mic one is pushed up as the feed to the Dugan is POST fader.
Do you see where I'm going with this. You could simplify the visual on this by returning the Dugan inputs to the second layer inputs 17-24
Mick Berg.
