Re: X32 Discussion
Hi Per,
The user manual contains a block diagramm. In this diagramm you can see at the left bottom corner the analog inputs, XLR and Aux. The analog gain, with the 2.5dB steps is located before the A/D convertor. As far as I understand such diagramms it is the triangle left of the A/D convertor. Then the signal comes into the block named IO/Patch. This is the area from which the signal can be routed to the UFX card. Now the signal goes via the DSP patch to the mix channels. In the channel you can find the ATT block where the digital trim takes place.
So far my understanding of the input signal flow. But I may be competly wrong because what do a mechanical engineer knows about electricity?
~:-D~:grin:
Hi Per,
