Re: P16M manual, EQ?
Greetings,
My question pertains to the P16M monitor mixer, so my apologies if this is in the wrong place - just seems that this thread has become the de-facto repository for all things pertaining to the X32 family...
First off: does a complete manual exist for the P16M? The extremely basic quick-start guide packaged with the device instructs me to find it online, but I can't seem to find it anywhere on B*'s website, or anywhere else on the interwebs. I'm usually a proponent of R'ingTFM before asking others, but as I can seem to find the manual....
After connecting the P16M to the X32's local ultranet port, and sending audio into the X32 via USB and XUF card, I was quickly able to get a monitor mix in the P16 using the direct outs on X32 channels 1-16. Cool; I'll get into subgroups later. Its great that there's EQ available on all inputs and the master output.
However, The physical EQ controls don't update to reflect the current channel selection. It would be great if they'd configured the EQ encoders like they did for volume and pan - infinite rotation with LED indication of encoder value, rather than a hard-stop 270 degree rotation potentiometer with a white line to indicate value. Oh well, gotta cut cost somewhere.
Lets say I adjust the EQ on CH1, move to CH2 and adjust its EQ, then switch back to CH1. I ASSume the EQ applied to CH1 hasn't changed, even though the encoders now represent CH2's EQ. If I adjust CH1 EQ again, do the filters 'jump' to reflect the physical setting of the encoders, and update from there? How do the light collars around these encoders function?
Then there's master EQ... It's too bad it's not as capable as the X32's parametric on outputs... Sort of precludes using this to drive powered wedges where high GBF is necessary. I guess I could set up and EQ a set of subgroups with the monitor EQ I need and send those to the P16...
Anyway, TIA for any input, and to all of you whose reviews and generally-gushing praise for the X32 system convinced me to take the plunge. I don't know if its a good thing or bad thing that my guitar practice time has be re-purposed to 'learning the X32.'
~:smile:
