There was discussion earlier in the thread about resolution trickery to get X32-Edit (or XControl, as I believe it was then called) to display full-screen on an external monitor, but has anyone worked out a way of making it do so on a MacBook with a 768-high screen (in my case, a MacBook Air 11")?
Because of the OSX Menu Bar, the app drops off the bottom of the screen slightly, which wouldn't be so bad except it doesn't let you drag the faders all the way down. They bottom out at -73dB (according to the Assignable Knob I put one on in order to get a second way of controlling it). Clicking elsewhere on the fader knob representation makes no difference. They still bottom out at the same point, not -INF.
I'm guessing that if I had a second something-by-768 display, it would display full-screen on that, with the menu bar on the on-board display, but that's not the point.
I have another MacBook Pro 13, with a 1280x800 display, on which it of course works fine, but I want to use that one next to the X32 for recording over FireWire, not for remote control.
And yes, I could use the iPad app, but I don't trust WiFi and I want to use a BCF2000 control surface.
In a closet somewhere I also have a very old Dell Windows laptop, with a 1024x768 display, but it's probably still running XP, if indeed it works at all.
Has anyone tried X32-Edit running in a Windows VM under Parallels on a Mac? It can be made to go full-screen in that, of course. I don't see why it wouldn't work, although I'm not sure about the BCF2000. Presumably that connects by USB in this context, so maybe Parallels does the right thing, and maybe it doesn't.
It's the silly OSX Menu Bar's problem, of course. There are apps to hide it, but they do only just hide it, not allow you to reclaim the space. At least, not one that I've found so far.
Sorry for the rambling...
