Re: TWO (2) inserts in the Master Buss
I've mentioned something similar at the behringer forum a while ago. It's worth mentioning here as well. The text has been slightly updated since posted at the other forum.
Maybe that is already said somewhere in this megathread. But I'd like to share a "routing trick" I used during the last gigs.
Routing the Master Out to a stereo Matrix and sending the Matrix out (instead of the LR outs) to the physical outputs gives you a second FX slot in this chain without eating up a bus. I use that for inserting the Precision Limiter _PRE_ fader in the Sum Bus. That leads to Matrix 1+2 where I can insert a GEQ if needed. Remember to crank up the Matrix volume to your max need and pan them hard left/right. I love the Limiter a lot, gives lotta felt volume to the mix.
As for a fun fact (at least I didn't know of this until today while playing around) it is possible to connect two rack-fx into a single mixbus using fx-inserts in fx[1..4].
The total path can then be: mic-->ch[1..40]-->fx[1..8]-->mixbus[1..16]-->fx[5..8]-->fx[1..4]-->matrix[1..6]-->fx[1..8]-->main bus-->fx[5..8]-->matrix[1..6]-->fx[1..8]-->speaker.
Example: mic-->ch1-->fx8-->mixbus1-->fx5-->fx1-->matrix3-->fx2-->main bus-->fx6-->matrix1/2-->fx7-->speaker
This is 4 inserted fx for a single channel plus 2 insert fx on the output
Also keep in mind that that most fx are dual mono so that instead of fx[1..8] it should be treated as fx[1..16] when it comes to routing.
Add to this the fx-send as well plus that you can route a mixbus to a different mixbus (by using a spare channel).
That's pretty cool!
