Re: X32 Discussion
I would also expect they have it on display, and release it just after NAMM. But that's not a problem. :razz:
The Dante Virtual Soundcard software has been $30 for at least a year now.I just saw at the audiante website that the virtual soundcard had its price dropped 80% from $150 to $30! 8O~8-O~:shock:~:-D~:grin:
I don't know if this drop in price is permanent or temporary.
Strange, when I checked a couple of months ago (around the time when Uli said that dante was a go) I never saw that offer. I also just found a note saying that the offer is time limited.The Dante Virtual Soundcard software has been $30 for at least a year now.
I would be surprised if it were to go back up to $150.
We'll see what thay say in reply to my email...
There was some talk earlier about Dugan automixer and some asking for it to be implemented. I see now that it has been released for Waves, so at least now it is possible to have it via Multirack. (As with any Waverack-application, it is advisable to have FiWi to avoid annoying latency)
The easiest way to incorporate it would be to send the Local1-8 etc. (or AES50 if usingS16) to the card in the card tab, then in the home tab, selecting card as input. The Dugan will then be inserted into the path of every input but you sill have processing etc on the X32.
More ideal, I believe, would be if we get the card as insert position in V2, then the automix can be post processing.
One feature I'am hoping will be added to the new firmware is a way to disengage motors when console is locked. I don't see a point in them having to move until the console in unlocked.
... Now that I have been indoctrinated into the ways of the X32 Rack's wireless workflow .....
Hello
Same here - Full-size X32 stays in only for rental now that I have X32R - iPad-mixing is so nice - and I already have a guy in line wanting to buy my X32 if I decide to.
Guess I gotta send in the venues console, the headphone monitor out suddenly only seems to be able to hear the LR buss, any other channel is super weak, and when pfl'ng those channels, the weak volume gets a little louder as you turn up the headphone until the knob gets to the 3'oclock position, where it actually turns the volume down all the way as you keep turning it up... Interesting...
I was able to route all the solo stuff out to the core and use it's headphone amp pretty easy though.
I was unable to reliably use the ipad around 0degC/32degF when I tried to mix remotley so there are uses for a physical interface at times.... Now that I have been indoctrinated into the ways of the X32 Rack's wireless workflow .....
Hello
My own personal preference is to do initial configuration on the actual console and then fine tune using the ipad. There are also some control options missing from the ipad that only the console and the editor can access.
Next weekend will be my first ipad-only mixing session, when I'll use the x32-rack on a small bar gig.
Link the bus and configure it as 'group'. This way the bus will be stereo and it will respect the repective channel panning.Hi, Just can't figure how to use a stereo bus... is there possible to hear panned channels thru a bus?
Lets say I have two channels, one pan left, one panned right. Stereo bus button its closed for both channels to hear them only thru the bus (not a sum of them). I sent them in a bus and I need them to be panned thru this bus but they are mono.
I tried to make the bus mono or stereo. I can pan the bus himself but the channels thru this bus are mono in the speakers.
Seams simple but can't figure out
Man.. Lots of folk in here lookin' to keep thier setups pretty small, eh? Makes my think of all those consoles it would take 4-6 folk to lift back in the day!
I tried out a few things on a conference this weekend:
Seems that my ipad lags and random app crashes way less when running all wired connections (console, core, laptop) into a network switch and running a seperate router to handle dhcp and wireless duties. I'd like to see if a managed switch would work better. I'd like to also try out the x32-router java app from flamenco, anyone here use it? X32 Router | TwelveTone
Also setup my core to handle extra comp duties on the line inputs fed from the x32 and back again, works great! Super nice to use the two knobs in the front dedicated to handle threshold and ratio functions quickly. Might not be too cost effective for just that purpose though.
Recording 38 channels into reaper seems to work great in mavericks on a macbook pro (late 2012) - capturing those extra 6 playback channels on the core. I had some trouble getting the core to be seen by osx, but then switched the 32x32 config down to 8x8 and it picked it up right away.
