Actually ( unless changed in v2 ¬ documented yet) it is a little more complex with the core as you cannot load a scene from the usb stick ONLY a show!is this relevant with recalling scenes also?
All saving would be done via the X32?
would it create any issues if we went through the Core with the Cat 5 link so it was already wired in in worst case scenario?Mike
Assuming the more sensible choice would be to go for the X32 Rack mount therefore meaning quick access to the menus in a situation, how would people suggest to set this up? ill probably think about having one of the s16 boxes in a rack with the X32 Rackmount, which will always be stage end, run a cat 5 from FOH through the x32 rack mount ( will this cause conflict issues if both have the same show on and should i just have a CAT 5 read to plug in from the S16 and bypass the Rackmount when running from the X32 full desk) then load the show Via USB pre guests so each console has a similar show on, in a failure of the main board, quick patch and grab the iPad and away we go... Next question, would you personally set up a router for each console or one at the desk end?
Mike
Yes, this is normal behavior for the x32Is it normal behavior that if you use FX 1-4 as an insert you still get audio back on the FX returns? I only see the audio on the meter and hear it on PFL. it's not send to the main, even if LR is activated for that channel. So you don't hear it but it seems to be strange when the fx is used as an insert. I'm running the 2.0 beta.
It would also be useful if you can easily switch off the RTA view. For example with the user buttons. Now you have to go to the RTA page on the meter section and turn the overlay to "off".
The Pro 2 does not have a touch screen so why would this? Look at the price ($4999 US) and that will tell you why it does not have a touch screen.Any word/idea when Behringer might release an updated version of the (pc/mac/linux) remote software? Seems like with the new feature set and issues some are having with saved scenes no longer working, the old control software wouldn't be compatible with the new firmware.
Anyone else surprised the M32 didn't get a touchscreen?
And one question Steve Young didn't answered in this video (because nobody asked) is if the network compatibility was tested. In other words, will that be possible to use M32 as FOH connected to X32 at monitors position via AES50 (whether with S16s or using X32 as a stage box). I suspect firmware differences may impose some limits (better not!). May be John Di Nicola or other Behringer or MIDAS people can answer: did anybody actually tested this setup, M32 with X32, especially with different firmware versions.
And if yes, will there be a new stage box similar to DL431 (where each physical input feeds three independently-controllable preamps, so the FOH and Monitor engineers can set up their gain independently). Something less fancy than 431, two preamps per input @48K.
If MIDAS is serious about bumping M32 to 96K in the future, it would be nice to have full compatibility with MIDAS Pro stageboxes (251, 351, 431, 451)
Dear all,
we are currently in the final testing stage of the X32 Dante, Madi and ADAT expansion cards for the upcoming production and shipment later this year.
We are also working on a 32-channel Direct-to-HD recording card for release early next year. More expansion cards are planned and will be announced at a later stage.
Next month, we will also be releasing an update to the KLARK TEKNIK DN9650 to operate with the X32 series. This will allow you to connect the X32 via AES50 to the DN9650 as a bridge to Madi, Dante, A-Net, CobraNet, Digigram Ethersound, and give the X32 external word clock sync. You can use any of these protocols via DN9650 expansion cards AND at the same time the X32's card slot for recording 32x32 to your DAW or as 32 inserts with Waves MultiRack or other low latency “Live Host” applications.
The X32 will also be compatible with the new flexible and affordable line of MIDAS stage boxes announced at WFX this week. They all feature MIDAS XL4 mic preamps and can be stacked in any configuration needed via AES50; all models are $1499 US MAP.
There will be four models, (DL151 = 24 in), (DL152 = 24 out), (DL153 = 16 in x 8 out), and (DL154 = 16 out x 8 in).
As mentioned earlier, the X32 is the heart of a large and continuously growing eco-system; at Namm 2014 we will be showing very exciting new members of the X32 family.
Warm regards
Uli
i just loaded all my show files
[only a dozen+...] on to 2.01b
-with no apparent errors
what i did:
flash desk
reset network settings
connect xedit pc to console
*do not synchronize*
load each scene and save
main caveat: you have to use the desk to save the file on the desk
x-edit cant write to the desk scene save
[remember spinning encoder labeling?...]
obviously if you want to xfer
a hundred scenes or a showfile this is not happening
but if you are like me and have a few generic start scenes
and a few client's shows saved it works if you want to try out the
new stuff on a familiar file
i'l wait on the updated edit program to do the core...
fwiw
The easiest way to incorporate it would be to send the Local1-8 etc. (or AES50 if usingS16) to the card in the card tab, then in the home tab, selecting card as input. The Dugan will then be inserted into the path of every input but you sill have processing etc on the X32.
More ideal, I believe, would be if we get the card as insert position in V2, then the automix can be post processing.
