Re: X32 Discussion
Found a bug in X32-Edit?
I installed Firmware 2.06 on my X32 yesterday, and X32-Edit PC 2.2 on my laptop. My typical configuration includes a 19" monitor plugged into the laptop on which I run two instances of X32-Edit, both showing meters, one for channels, and one for mix busses. Incredibly handy, and has worked well in the past (aside from the problems with dropped communications to X32).
New problem showed up yesterday. The instance running channels would freeze, but the problem didn't seem to be dropped communications like before. Switching to a different set of meters would immediately restore operation, and switching back to channels would then work fine for a while (1-2 minutes). As a test, I stopped the instance running busses, and then channels continued to work. I stuck with a single instance from that point on, doing no further trouble-shooting. Is anyone else running multiple instances of X32-Edit for metering? If so, have you seen any freezing problems.
At one point I switched to the RTA display in meters in one of the two instances of X32-Edit running, and I believe that also froze fairly quickly, but switching to a different tab restored operation instantly.
