Re: X32 Discussion
Churches and schools.What kinda places you work, Glenn?![]()
I have one problem in live events. I use X32 RACK with 2 subs JBL PRX715XLF and 2 tops PRX 712.
When I play on my arranger it is super sound.
But when I sing on my microphone in low frequencies, I hear some noise "zzzzzz" in back of the JBL PRX712.
When I shut down all low freencies the problem is gone, but the sound of my voice is unnatural.
Please help me.
Check the manual for the S16. There are modes, follow direction on how to set the correct mode. Only a few of them use AES50 ext sync, 1- 6, and plug S16 A to console A, sync the console to internal, and S16 to AES.Hello I am having an issue with a S16. It will not sync with x32. Have tried a rack and a console. All setting are as behringer suggests and tried several ethernet cables. I can get it to show up when I connect the A from rack to B of the S16 with S16 running clock but will not pass audio. A x A with board as clock will not sync and the red light does not even flash. Has anyone had any similar issues and or suggestions to resolve this issue.
Update on the sync issue. I rebooted both units several times, downloaded new firmware and rebooted several more times with no luck. Took a break and fired up my camera to make a quick video of the issue and it synced right up. Have restarted several times with no issues. Going to keep an eye on it.
What cable are you using?Update on the sync issue. I rebooted both units several times, downloaded new firmware and rebooted several more times with no luck. Took a break and fired up my camera to make a quick video of the issue and it synced right up. Have restarted several times with no issues. Going to keep an eye on it.
Ethercon. Will have to check the brand. I tried several straight up ethernet cables as well. Just a windows phone. Could upload it for the sheer comedy value. Talking up this big issue only to have everything work.
Dear friends,
Please tell me how to control volume level of AUX OUT 6 and 7 on X32 edit software, because I have X32 rack
I don't remember your earlier posts so this might be redundant.Problem is back. This time I got it on camera. Any advice would be appreciated. Tried to contact Behringer support about a week ago without any response.
