Re: X32 Discussion
Hello Jan, and thank you very much for the helpful reply. I appreciate you taking the time to answer my questions.
I have just one more question....
I plan on connecting some unbalanced line level sources to the mic inputs 1 - 16. Do I need to connect/tie the - minus/cold side of the balanced input to ground? or do I leave it floating and just connect the input device shield to ground.
Thanks!
Glenn
Thanks!
Glenn
Dear glennfin,
The four internal stereo FX1-4 returns are always available, and stereo FX slots 5-8 are supposed to be inserted into channels or buses. This is completely independent from the physical aux connectors. The X32 Rack rear panel AUX IN/OUT connectors can serve multiple purposes, such as Direct Outs or Inserts in channels or buses, or as additional in/out. They are meant as auxiliary line-level in- and outputs, in addition to the fully equipped Midas mic preamps on inputs 1...16, and have nothing to do with FX sends or returns.
In your example, you may of course use say Aux Out #1 for sending out a bus signal or a direct out from an input channel and use that as a send to your Eventide effect, by adjusting the signal source on the Routing/Aux page for that connector. The return of the Eventide may be put on any sort of inputs you like, e.g. Aux In #1 (and #2 if it is stereo). This way your Aux 1-2 faders would be the FX Return faders for your Eventide. You may also run the Eventide return into a Mic/Line input 1-16, or feed its input from any one of the XLR Outputs 1-8 ... everything is configurable.
The general in/out Routing is (mostly) structured in blocks of 8 channels for quick and easy connection of external devices, such as networked stageboxes or interface card signals, to the X32 dsp processing. Once connected to the dsp, any signal can be used in any channel (see channel configuration Source) and there is no such block-wise restriction of patching signals to channels or outputs.
You may also consider downloading the free X32 EDIT application from our website, which allows you to familiarize yourself with the functionality.
Hope that helps.
Kind regards,
Jan
