Looks good ..
Where did they come from?
Not a x-over, but you have got the low pass and high-pass on the outputs to allow you to implement a low-order x-over. You'll find a discussion about this early in this thread.Hey guys,
I haven't been able to find anything in the documentation -- and we know how spotty it is -- but is there an output crossover? I've been using the x32 for a couple of months and have another on order for a permanent install. I don't bi-amp my mixes, but this permanent install currently uses a crossover to biamp the mains. Obviously, I'd rather do everything from within the x32.
Worst case scenario, I can change the wiring and run the speakers full range.
Thanks in advance!
I do believe your right.
Thanks;
Douglas R. Allen
Sorry for staying off topic, but how are the Seeburg speakers compared to d&b and other top-line makes? Can they compete? Really like the look of the K24, would be ideal for my use if the also sound anything near d&b Q10.Yes you're right, it's a Seeburg G3 with Galeo Sub and two Seeburg TSM 12 as Frontfills.
Hi Josh,
First and foremost, I want to thank you for choosing BEHRINGER, and purchasing an X32.
I can tell you we are doing everything in our power to listen to you, our customer.
USB Stick:
I am reaching out to our development team in Germany and will see if there is a specific USB stick they have qualified. I want to point out that this is a USB stick issue, not an X32 issue. Bottom line, some inexpensive USB sticks have slow buffering, not allowing digital audio recording to work properly. Also, note many user issues with the USB recording functions, have been, user related, as they have not followed the manual and formatted the stick for FAT32. Note, the manual does recommend: "Please test the recording capability of your USB device before you do the “real stuff” as some sticks may not be supported or be too slow."
Page 32 of the X32 Manual:
5.16 Recording a 2-track directly with the console
The X32 offers the possibility to record a 2-track of your mix (or any other selection of signals) directly onto a USB-stick/external USB hard disk:
• Plug a FAT-formatted (FAT12, FAT16, FAT32) USB stick into the USB port next to the main display.
• Press the VIEW button next to the USB port and the home screen of the recorder will show up with a nice emulation of an old tape deck.
• On the config tab you can select the source for the recording, default is main L and R.
• Press RECORD (encoder #5) to record your mix.
• To adjust the volume during playback, press the AUX IN / USB FX RETURN button next to the fader section and adjust the volume with the AUX 7/8 faders.
Remarks:
Due to the FAT format of the stick, the file size will be limited to 2 GB, which is about 3 hours of stereo recording. Please test the recording capability of your USB device before you do the “real stuff” as some sticks may not be supported or be too slow. We also recommend you defragment your USB device prior to recording. The recording will be done as 16-bit WAV file with the selected sample frequency of the console.
Please also note that it is possible that the specifications of USB storage devices may be changed by the manufacturer without any change in physical appearance or notification.
In regards to the iPad app:
I have seen information about the final iPad app for the X32, and can say you will not be disappointed, it will rival anything in the industry, but it is taking time. The X32 just hit the market approximately 1 month ago. We have addressed any issues with near immediate firmware upgrades, as this is the immediate need. The iPad app will follow suit with updates as we add functionality and just like the X32 itself will have an unprecedented feature set.
Service Issues:
In regards to any service issues that have come up (and there have been relatively few), we have diligently been helping those users in every way possible. I urge any user to send me a PM if they need help in any way with there X32.
Once again I want to assure you, we are listening to you the end user, and value your business.
Joe Sanborn
Manager, Channel Marketing
MUSIC Group
BEHRINGER
Hey guys,
Thanks in advance!
Hi all!
I've had my X32 now for about a week and I've been slowly getting my head around the many options and confirming that everything works as intended. Great piece of kit!
Where I'm struggling is with the XUF USB / Firewire expansion card. My intention was always to use an old Acer laptop to record 32 channels via USB using Reaper 4.0. I had the laptop already set up with Vista 64 fully patched and Reaper but my USB ports were playing up. I bought another USB port on a PCMCIA card to try that and I cannot get that working either. Then I tried another laptop and can't get it working. I just don't appear to have any evidence of audio appearing in Reaper in any way.
I don't really have any experience with Reaper so it may be something there that I'm doing wrong, but I am a pro audio guy and I'm also a pro IT guy so after 2 days of fiddling, I'm beginning to suspect the XUF card is faulty. I also noticed on the main X32 screen it says XU with a green light, not XUF.
So, anyone with experience of Reaper and an X32 have any pointers? It's got to be a hardware failure or something simple that I'm just not seeing in the Reaper manual.
Thanks in advance.~
~:smile:
Kind regards, Andrew
Mama - The UKs 'all era' Genesis tribute band!
Carillon Video - Professional Wedding Videographer & Wedding Video Production Services in Bolton, Manchester & all over the UK
Hi Andrew, when you open the control panel of the Behringer USB driver, does it recognises the X32 with its ID number? Are you sure, that you activated the Behringer Asio driver in Reaper?
This is my first experience with a digital board and configuring it.
Essentially I am trying to figure out how to control my stage monitors. I have them patched into the AUX outputs (simply because I didn't have any XLR adapters on me).
The X32 control panel software does indeed identify the X32. It also populates the Input and Output channels and ticking the box to specify hardware names to be included also makes the inputs appear differently in Reaper....
Save as scene, if you only want the typical systems parameters to be reset on scene recall you should Safe the rest of the parameters before saving the scene. Maybe save one with no Safes for full restore as well.Is it possible to save systems to a "default" file and keep that on a usb drive for safe keeping in the event someone comes in and changes things?
