re: X32 Discussion
Just an update for this situation. I'm very pleased with the support I received from Behringer. I pm'd Joe Sanborn about this and received a call back within 10 minutes. After I mentioned that I'm in NYC he said that John Dinicola lives close by in NJ and would be able to help me out. So John calls me a few minutes after I get off the phone with Joe and we arrange for him to come by the club yesterday afternoon.
I should mention he offered to come the same day but I already had our old Venice installed again and it was Saturday night and too late to swap consoles at that point but I thought it was great that he offered.
So John swings by the club in Harlem yesterday and confirms no input from channels 9-16, and 25-32. He then gave me the option of him taking the desk and having it fixed and leaving the loaner X32 he brought, or him fixing it there on site. I opted for the latter as it would be easier for everyone involved and was assured the warranty would be fully intact.
He pops open the console and checked all the ribbon cables. Although it appeared everything was fully seated, he unplugged and re seated the two corresponding ribbon cables and sure enough I had signals on those channels now.
After we did a noise test on every channel and we ran into the issue with noise on channel 16 due to a power cable running too close to the preamp on channel 16. So we opened the console up again (luckily hadn't put all the screws back yet) and he re-routed that power cable which required unplugging the ribbon cables for the output cards. We tested 16 and it was clean and then tested all inputs and outputs one more time to be sure and all was good.
John is a super nice guy and very easy going. I was impressed that someone was able to personally come by the club and address the issue and to me this indicates that Behringer is very serious about making sure customers are happy with their purchase.
As for the X32 I won't be installing until Thursday but spent a couple hours configuring and playing around with it last night and so far really like it. I also tested the firewire recording function and card playback with a Reaper session I had on my laptop and had absolutely zero issues getting it setup. Installed the driver on the comp, and Reaper saw the X32 right away. This is important because we do a lot of multri-track recording there and that was one of the major selling points for me and this will make my life much easier than dealing with out current Fostex hard disc recorder.
So thanks again Joe and John, if either of you are ever in the area you're more than invited to check out the show and have a few beers on the house.
EDIT: Oh and I was able to update the firmware by forcing a reboot by switching sample rates with the usb stick in.
Installed the console and I'm testing every channel. It appears I can't get input from channels 9-16 or 25-32. Haven't test all the outputs yet except for 15/16.
I've verified the routing is all set to local inputs, and when I assign inputs 9-16 to local 1-8 I get signal on those channels. Perhaps I have two bad 8 channel input cards. Unless this is something I'm missing I'm none too pleased about this. To be fair, the same thing happened with our SC48 output card so I'm not gonna knock Behringer on this, but can someone from tech support please contact me?
I've been on hold waiting to speak with tech support for 20 minutes and have don't have time to sit on my phone all day.
Thanks.
EDIT: Also tried doing a firmware update but when I plug in the usb stick and power on it won't update so I'm stuck on 1.02.
