Re: Firmware v1.10 Release Notes
We have just released version 0.9 of the XControl PC software that matches the latest 1.10 firmware and now features full functionality.
Oh yes, nice, nice, nice, just what I needed yesterday when I was programming yesterdays show on the PC and somehow managed to lose the preinstalled tap function on the delays :blush: I guess now is the time to figure out how to save and recall the assignable section, as I'm not aware of any library function for this.
I don't really like the logic behind removing the scribble strip from HOME-config, assuming that it is a move towards making it less confusing, but hoping it does not signal a move away from making functions context sensitive, as it only replicates the HOME-home and HOME-main utility functions. Logic would dictate that context sensitivity was somehow similar across the tabs, ie. that home-utility would do a total channel recall, config-utility would only recall what is present on the config tab, like what you have on the gate, dyn, eq and sends tabs, and by the same token, main should only recall the functions on that tab.
I know it is a matter of preference, but consistent logic is allways good, I think.
Insert scene, with warning when it is full, yes, good. One can easily device a working method where one would do a backup at the point when the initial warning is given, and start building a show2 from that backup as the spillover loses scenes (takes some mental housekeeping, but entirely feasible) :thumbup:
The separate mute and fader sends are a godsend, makes a huge difference to the smooth running of a play, ( again I wish I had it yesterday
~;-)~:wink: )
:thumbup: :thumbup: :thumbup:
