Re: Monitor Out Whine
What I'm proposing is a very simple test procedure that the console can perform on itself, with easily readable results. Simply load the scene file, plug the xlr into input 1, then plug into the output you want to test, and the meterleds and the gateled on the first few channels will tell you if you have random noise above spec and if you have single-frequency noises more than 3-6 dB above the random noise floor. A full diagnostic of all outputs on a board should take a couple of minutes.
Yeah, that seems a lot simpler :razz:Simpler yet: a console, an XLR lead, and a computer with an XLR interface and a copy of SMAART or something similar.
