Re: ipad ipad ipad
B&H now shows expected availability date for the X32 Rack as October 25. Ouch.
I know there is someone daring who has updated their iPad to iOS7. Anyone care to comment if X32 Mix is still functional?
Does anyone have a good recommendation for a (relatively cheap) UPS to use with the S16s?
On the P-16m midi implementation, any chance to get any info?
Stand corrected !! !
( it was the iPad bit that I couldn't recall as I was more interested in the x-control now renamed the x-edit - weak excuse I know) but as you remembered it possibly pepes could now use it!!!
Hi Jan,
Please, is Behringer on the way to extend one more Port for AES50 via extended card for 48 channels 48kHz sampling?
Or Do you have any other external solution inside of Music Group from Klark Teknik or Midas?
Thank you in advance for answer.
kr,
Jan
As mentioned many times before, I use a Eaton 3S with the X32, it's small and hardly cost anything, and works flawlessly.
<snip>
In thinking about the subject since last night, I remembered the Wiki that he so graciously volunteered to head, and which I volunteered to help with after my busy summer was over.
Summer is over for me, and I went to his link for the Wiki to find that it is trapped in the Behringer site meltdown/clog, and so currently unavailable.
In putting the two concepts together ("Wiki organized so that info is findable" and "this thread contains all knowledge about the X32 and its ancillary devices/processes"), it strikes me that this thread could be treated as an information mine, with miners attacking limited sections of it (pages 100-110, for example), and adding information to the Wiki framework outline. That way no one would have to sit down and spontaneously write all of each part, or the section they were somehow assigned to do ("write all there is to know about the motorized faders" or "write about how to use Reaper to record 32 tracks", for examples).
The Wiki clearly should not be only on the Behringer website; don't know what's up with that or why it's taking upwards of a month to fix.
About the Wiki, I more or less told Joe, John and a focus group that I have given up on the Behringer site for the Wiki and will instead install a Wiki on X32user.net and do the project there, the main reason for this is the difficulty of getting the proper access and getting anything done in the Behringer web system. I had hoped that the restoration of the Behringer web would let me get to a current copy of the Wiki, my backup is quite old and contains about half the work already done :?~:-?~:???: (unfortunately I can only blame myself and will never learn).
However, when I have some time available, I'll set up the Wiki at X32user.net, and get in touch with the volunteers. The wiki install will be the same as on the Behringer site, so a subsequent transfer can take place at any time.
I think I got buried under iPad posts. Any suggestions to my above question?
More than likely, many like me ignored it since it's been discussed ad nauseam in this thread already....
A photo copy ~:-D~:grin:nuts... much like quite a lot of access to files and while using the search function on the Behringer.com website, I cannot seem to access it...
All I get is this:
An error occurred while processing your request. Reference #97.4e9b33b8.1379606599.cdd26cd
Never seemed to have stumbled upon that file on the website yet, where is it buried?
I know you folks have been having server issues, but perhaps is there any other redundant method of access to your files, maybe ftp or something?
The link I gave is for P16-M, and it is available in the documentation drop-down of the P16-M product page at behringer.com.
It should look like this. Anyway, I will follow up why you might have had access problems on behringer.com
Oooops, seems like I can't read correctlyThe one that Robert provided is about the S16 MIDI remote control. Unfortunately, it is not in a separate document, but only on p.12 of the English user manual, which you can find in the S16 documentation drop-down... http://www.behringer.com/assets/S16_M_EN.pdf
